Hi Support,
The sidebar ad on the front right of the site has stopped being sticky.
https://frenchmorning.com/
All other sites are working fine. The sidebar front ad sticks to the top of the browser window as you scroll down the front page.
https://frenchly.us/
https://london.frenchmorning.com/
Maybe the setting is disabled in the theme panel – http://prntscr.com/myc8sn
If that is active it should work. From what I can see the sidebars are not sticky in the posts as well. Please check if that setting is active.
Where would I find the setting for the sidebar ad sticky?
What setting are you referring to exactly? Some more details would be helpful. The general setting that I mentioned in the theme panel is required to be active in order to have sticky sidebars.
In the composer there is a setting than has to be active for the columns you want to be sticky – http://prntscr.com/mzdjd5 but this will only work if the general setting is also active.
Regarding the post views I don’t quite understand what you want to do with them. Some more details would be helpful here as well.
Let me know.
Just saw your reply here.
How do i get to the edit screen in your image>?
