Front pages front is broken please help me out its emergency.
my website is tbtbangla.com . when anyone visit it they got broken fonts but in my pc its ok. only happening for pc please solve this
It seems you use a font that is not compatible with chrome. On fierfox everything seems fine.
Also please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
i have made my site with 8.5 version and customized after default demo installation. Didn’t install any custom fonts. But after caching it showing this error only in google chrome desktop ,another thing is in mobile version tab to top option is not included. didn’t add any custom code, just google analytic and Facebook instant article code are placed in the theme header. please reply this thank you.
The issue seems to be solved at the moment, the website displays the font properly on all browsers I have tested with
https://www.screencast.com/t/sasMsVcY1ZT
