Full width element to always stay below block and sidebar on post pages
Hi!
I am wondering how I can put a full width element, for example a revolution slider, at the bottom on a post page without having the sidebar going over this element when scrolling to the bottom of the page. See attached picture for best explanation of this:
https://imgur.com/a/pbiwg
Link to website: https://www.bitcoinakademiet.no?bypass=tagdiv
Thanks a lot!
Hello lettogsunn,
I have inspected your website and I saw that your sidebar seems to work as expected, without any problems and it does not overlap anything. Where exactly is the error? Clear all the caches and check the results.
Hi and thanks for your reply.
I deleted all cache files and still have same issue, so I was maybe not clear when explaining: to include the revolution slider at the bottom of every post I edited the post template .php file and added a php echo shortcode. The result is that the slider is shown just above the footer on all posts, but the sidebar will NOT stay above the slider when I scroll down to the bottom of the page. You will see the issue in the image I linked to (you see 2 posts from the block widget overlap the slider above the footer). You should also see the same issue if you go to any post/article on the website.
Any solution for this? I want to force the sidebar to not scroll further down than the actual post content.
I have reinspected your website and I saw the problem with your sidebar on the post pages. Notice that error does not come from our theme if it is right used, without any untested plugins and without any customizations. Try to disable all of the untested plugins, if you are using something like this, clear all the caches and check the results. Also, if the issues are still there, try to make a new clean install to another subdomain via FTP way, clear all the caches and check the results.
