Hi there, i want to remove that gap at under the menu. (1) And i want remove that hover color at slider. (2) How can i do? Thanks. https://ibb.co/jyWQyyh
In order to remove the gap you can edit the page and set to the first row a margin top
-40 https://www.screencast.com/t/XHpfT49oE9U or you can use custom css -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
If you need help whit this please provide a link were I can inspect the problem, in this way I will be able to provide you the right css.
If that is a slid you need to edit that page, click n the element Slide and check the hover color overlay on style section https://www.screencast.com/t/0QhpDTjxo
