How do I tighten the gaps – way to much white space in between each post. Thank you. The page is https://infomeddnews.com
I believe you are referring to such spaces – https://www.screencast.com/t/eLteZt0r
That will happen because some of the posts seem to not have featured images set. If one post has a featured image the module will display a thumbnail, for others not. This will cause uneven spacing
– https://www.screencast.com/t/5PTrAn0Tcf
Either set featured images for all posts that don’t have one, or remove them all maybe. Or use blocks that do not show a thumbnail, like block 9 and 10.
If there is no featured image set, there should be a placeholder displayed
– https://www.screencast.com/t/RWUTAt31
You could hide the module thumbnail for his type of block, to make them look better. A code like this will do that (affects only blocks 4 on the homepage)
– https://www.screencast.com/t/rCZfu4uD
.home .td_block_4 .td-module-thumb {
display:none;
Also the title and content length can be controlled, for this module here
– https://www.screencast.com/t/Dg5InixbHqQp
So you could limit the excerpt length for the modules, they will look better.
