Dear Support,
I have General Modal Image is ON
After saved settings I created new posts with images (individual settings of images is off) and images does not show in popup/lightbox view.
I must edit image, set lightbox on and set link of media files. After this settings modal view works.
In all cases we need a set individula images to set lightbox on.
Is that ok?
Thanx in advance
BR.
I checked and for me works -> https://www.screencast.com/t/Uj2YqQnrv please make sure that you don’t have a plugin conflict.
Well…
We don’t use Gutenberg and is not in our plans. Bettina told me you have a bug reported and confirmed about this issue. More than 4k post were ruined because is related to the general modal. So, this is not an option. If you can confirm this probably (because nothing is sure in life) be fixed in the next update, this would be a little relief.
Dear Anamaria and gcamaram,
yes, we use Clasic Editor Plugin!
I just tested and Anamaria is right…
Only added images without edit images, additional settings for light/modal box!
When created post in Clasic Editor – Modal not works
When create post in Gutemberg Editor – Modal works!!!
URL: https://nook.rs
Welcome to Newspaper!
Version: 12.3.1
System Status
PHP Version 7.4.33
Classic Editor Version 1.6.3
I agree with gcamaram for fix this in next update.
Thanks a lot.
BR.
Now I have the same Problem with the Classic Editor. When does the Fix come? 12.3.1 is the issue.
This reply was modified 3 years by
mbbaureihende.
Dear Anamaria,
Thank you for the info!
Have a nice day.
BR.
Hi, should it work on the 12.4 Update? On my Site it doesnt work after the Update. Or should we wait a little for the 12.4.1 ?
Thank You
No, it doesnt work for me. Its generally active but it only works when i activate it in every single picture manually.
– admin url and credentials
