I’ve tested the general modal image on my side with the latest theme’s version available on themeforest, V 2.3.4, and works fine. Please make sure that the link for the image goes to media file: http://screencast.com/t/YHiCovhQta deactivate all plugins except Visual Composer, clear all caches and test again.
I have linked to media image, and the error is only when you upload new content !
/Jens
Try to deactivate all others plugins except Visual Composer, just to make sure that there is no conflict with some other plugin, clear all caches then check again.
If you can’t still manage to solve this issue please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
Please make sure that you updated the theme according with our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ deactivate the child theme, empty all caches, deactivate all plugins except Visual Composer and test again. Also you can try to make a fresh install on your computer, only with WordPress, the theme and the Visual Composer plugin and check if this issue is still there.
If the problem persist please address as via email and we will inspect it in shortest time possible.
