good evening, I have a problem with the colors of the site. a problem a bit 'str
good evening, I have a problem with the colors of the site. a problem a bit ‘strange. I try to explain myself. I changed the background color of the top menu and the main menu. everything works, but when I update the page or change page for a few seconds the old color (black) comes back and then the color chosen by me reappears. why this problem in the page refresh? thank you
Hello pepix90,
Try to clear all the caches and browser cache and check the results.
Thanks for you reply.
Sorry my last question.
If i use the plugin: td-theme-mobile, I must put the google analytics code, or is taken automatically from the main theme?
P.S for the boxed layout the solution is use a backgorund color or image, true?
Hello pepix,
Regarding on Google Analytics code, notice that you simply add the code in the right section from here -> https://www.screencast.com/t/ggFzivri4EFh
Yes, you should use the background color or image if you want to have a boxed layout.
