Website indexed in 10 seconds while using the old theme, Right now, does not index articles since I switched to the newspaper theme. How can i fix it
Yes, they work fine but I see something new, after changing the theme, the sitemap is automatically sent to the webmaster every day. Could it be related to this ?
What tool are you using to create the sitemap? We only recommend seo yoast:
https://kb.yoast.com/kb/enable-xml-sitemaps-in-the-wordpress-seo-plugin/
So, your Google search console account shows no errors for your current sitemap?, and you have no F12/console errors for the skipped page?.
Theme doesn’t control sitemap; so if your Yoast sitemap is working (did you test it via search console and in browser?).
Then should work. So, can’t be of much help without more info.
Good luck!
(I don’t work here; but I’m out on this one. Sorry no help.)
This reply was modified 9 years by
simchris.
The exact thing is, I can not get an index without using the google send url with newspaper theme. However, as soon as I wrote an article about the old tema I was getting an index in 10 seconds.
Yoast seo features are the same, sitemap is the same everything is the same.
This was after the theme change.
There could be a plugin conflicting with the theme.
Please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Then test the indexing again.
