Hi, i am trying to modify the single post template in the gourmet pro version of the thema, get rid of the sticky smart sideabar and expand the content, but i have tried everything and not be able to do that, i’m sure i’m missing something so easy… but i’ve wasted a lot of hours to no avail.
If anyone could help me i’ll be so grateful….
You can delete the elements with right click -> https://tagdiv.com/right-click-menu-tagdiv-composer/ after you need to change the layout of the row -> https://i.imgur.com/wd4u5M7.jpg
