With your theme I have notice a problem displaying my gravity forms on posts, a number and a button appears right next to it, also to add a new one, instead of the pop up with the entries for me to input the name I get a black screen and nothing loads and finally there’s a bug with the favorite’s menu on the post, when I use scroll up,it covers the post, please check the images so you can see.
My site is: http://www.oteacher.com.br
Hello lilioligue,
Unfortunately, but please notice that our theme does not have any Gravity Forms code implemented, sorry! Most likely, you are using such a plugin with this functionality which is not tested with the theme and which might interact with the theme core files and cause a lot of unknown issues through the theme, like this. Notice that we cannot offer support for untested plugins.
Neither can you help solve the issue with some sort of code?
I mean gravity forms is a very popular plugin and it is very pricey and I would like to able to still use as I used to.
Tks
