I think that you are referring how to set products in blocks, if is this, the you can set them with tagDiv Composer, then you can use the fitter tab just like for normally articles https://i.imgur.com/uCTXdRZ.png there you can set the product category, or you can set multiple product categories, and you can choose the sort that you want.
Also if you want to create in woocommerce a grouped product, you can use this guide -> https://beeketing.com/blog/create-woocommerce-grouped-products/
I hope this is what you need!
Please provide a screenshot with exactly what you want to achieve.
A solution for sending a screenshot is this:
Please follow the exact steps from this tutorial: https://www.youtube.com/watch?v=UCuVK53sSzY
unfortunately this does not solve my problem.
I have imported the template “Make Up Shop” and here the grouped products are not displayed. In the Woocommerce standard template it works fine. Therefore the question, how do I get display also in Newspaper?
I`m searching for something like this.
Instead of Upsell Products, grouped Products.
I hope you understand what i mean 🙂
If you referring to have here the grouped product => https://www.screencast.com/t/GyRpcKkene, then, unfortunately, this option isn’t yet added, but in the coming updates, we will try to add more options.
I believe we should discuss this again from the beginning. This is somewhat confusing unfortunately.
You mentioned grouped products https://i.imgur.com/atuR4dW.png
Which I believe means related products. Products can be related by categories and tags. The option to display related products by categories, or tags, or both of them, is available in a product block https://i.imgur.com/8REGIyM.png
If grouped does not mean related, what does that term mean exactly? What should the relation between product A, B and C be exactly?
Please mention some examples of a few more details about this, we will improve the shop plugin in the future and all suggestions will be helpful. Let me know.
Hi, it probably makes sense to discuss it again from the beginning.
For example, I have created this product.
https://www.screencast.com/t/QvtgLGs1W8
At the moment the grouped products appear like this: (this is the woocommerce default template)
https://www.screencast.com/t/yGn5XtnKDaq
If I now import a template for the tagdivcomposer, I can’t find a way to display the products.
I hope it is now understandable what I am looking for.
This reply was modified 5 years by
Freestate.
Indeed, this implementation for grouped products has not yet been implemented, but this update was made to solve certain problems, not necessarily to add new implementations, but this implementation is put on the to-do list for future updates.
