Do you have some guide for absolute beginner users of this theme? I have a lot of experience with WordPress and programming, but with this theme I am completely lost. For example, tagdiv articles and tutorials start talking about ‘blocks’but nowhere that I can see explains what blocks are and even how to access tagdiv. Thanks.
This topic was modified 8 years by
guischarf.
Hello guischarf,
Please notice that our theme uses bocks which are made up of modules. Please check here -> https://www.screencast.com/t/NvdPod4XL Did you have read all of our documentation and you did not understand how you can use our theme? Please start reading it from here -> https://forum.tagdiv.com/newsmag-newsmag-documentation/ What exactly you do not understand?
Hello, Catalin. Thanks for your answer. I had read the documentation when I wrote, but have not found information about various topics which are very important. For example:
- How do I create new blocks using pre-existing modules
- How do I insert new blocks or modules in the header area. Header seems to be all presets just controlable through parameter twicking
- Is Tag Div and WPBakery the same thing? If not, why I do not see a TagDiv menu on WordPress back office, but do see a WPBakery one?
Thanks again for your response.
Guillermo
Hello guischarf,
Please notice that our page builder cannot be used to edit the Header Section, sorry! On the header section, cannot be added any modules/blocks at the moment, sorry! If you want to edit that section, you should edit the theme core files, where the header section is created.
Hello guischarf,
There’s no such a useful guide for this because this is not a simple task which involves doing such an additional customization. If you are not an advanced user, we do not recommend to edit something like this because you can break the theme functionality.
