Gutemberg blocks for posts
Do you plan to add blocks for posts?
At the moment, the only “fancy” block in “Media & Text” but it doesn’t work well as soon as you try to specify a specific value for the width of the columns. It would be great to have some templates…
I haven’t experimented much with the Gutenberg editor, there were tests made and should work properly with the theme when it will be released fully.
