H1 seo problem on mainpage
First of all: Thanks for this theme that I am using for years on several projects.
However, I am currently running in the following problem:
– I am using V 10.3.2 with the Global Header Cloud Template – Tech News Pro.
– This is using the Logo text and Logo text tagline as H1.
– Furthermore, it is generating an additional empty h1 tag resulting in two h1 tags on the homepage.
– If I disable H1 on logo via settings it’s still using the empty h1 tag.
My questions:
– Where is the empty h1 tag definied?
– Is it possible to just use the title and description as an h1 on the homepage?
Thanks,
Holger
Usually the h1 is set on logo, if you are using a cloud header from tagDiv Cloud Library, you can have a different H1 per page/posts, another way is to using the Page Builder + Page Title on page template, this should set your page title as h1 and remove the h1 from logo.
If you want that your title to have the h1 set instead of logo, then please check if you are using a cloud header, if yes, then you can edit it with tagDiv Composer and disable the h1 -> http://prntscr.com/q1ohji from desktop and make sure that you do the same for mobile logo -> https://www.screencast.com/t/xVUjIMUelXA2 -> https://www.screencast.com/t/ABTw6DUnbMjH and the problem will be solved!.
Hope this will help you!
