H2 and H3 Headings Too Small in Live Posts (Gutenberg Editor, Newspaper Theme)
Hello, I’m using the Newspaper theme with the default Gutenberg block editor. In the editor, all H2 and H3 headings appear correctly styled and sized. However, when viewing the live post, those same headings are rendered extremely small—almost unreadable—on all devices and articles.
I haven’t made any CSS customizations or used a child theme. The site is running WP Super Cache, but clearing the cache doesn’t fix the issue. The problem seems to be related to the theme’s default CSS or its compatibility with Gutenberg heading blocks.
How can I restore proper heading sizes on the frontend without switching to tagDiv Composer? Any help would be appreciated!
h2 and h3 too small
correct size in editor
site: curadelpeperoncino.it
HI,
If you are using a single post template, then you need to use tagDiv Composer, edit the template and select the post content, then adjust the CSS size – https://i.imgur.com/EJyPnO3.png – https://i.imgur.com/1fdbsc5.png
