Has Anyone Used WP Pro Advertising System With Newspaper 6?
Hi Everyone,
Has anyone used WP Pro Advertising System with Newspaper 6 before? Our project is not based on used Adsense, but to have direct advertisers in the website. For this reason we need a robust Ad Management System.
The WP Pro Advertising System allows for us to let advertisers log in, get their stats, manage their campaigns if they wish to do so and many other features.
Based on anyone’s experience, of course, our next question is how to integrate this with Newspaper 6.
Thanks for the help and feedback.
Simple to place in templates via shortcode and widgets in sidebar.
Hi Chris,
What about adding the ad codes into the main body between sections on the home page for example?
Thanks for your feedback.
Homepages are made with visual composer so yes. You can use the theme’s ad widget or use own code.
You can use the plugin shortcodes also in the theme ads sections from Theme Panel > Ads – http://screencast.com/t/zY1bQVFe6Pv as the theme ads system was designed to run shortcodes – https://forum.tagdiv.com/header-ad/ and use Ad box block to display it on the page – http://screencast.com/t/uI2YhfPgM
