Have Pages not Posts appear in Block
On my homepage I use several Blocks that automatically populate with Posts.
Is it possible to have all Pages, not all Posts, appear in one of the Blocks?
I’d like 4 specific Pages to appear in one of the Blocks on my homepage.
Here’s my homepage for reference:
https://impactmagazine.ca/
  • This topic was modified 5 years by IMPACTMag.
I’m not sure I fully understand what you are looking to edit. But, those modules seems to be default ones, so you can not customize them by TagDiv Composer. Unfortunately, for those modules you have only some settings in the theme panel.
If you will use a cloud template, then we have some more extra settings and you have the possibility to customize them easily with TagDiv Composer plugin.
Hi Bettina,
My homepage:
This homepage was built using the TagDiv Composer.
There’s a ‘Block’ near the top, called ‘Featured IMPACT’ that displays 3 Posts (‘Canadians to Watch at Tokyo 2020’, ‘IMPACT Picks for the Best Outdoor Podcast’, ‘Erica Wiebe, Canada’s Olympic Sweetheart’).
Instead of displaying Posts, is it possible to adjust that Block to display 3 Pages?
Unfortunately not. Blocks only display posts content at the moment in Newspaper Theme.
