Hey there,
I am having trouble having the 2 or 3 images fit to the width, set within the column of the website. (for example 1/3 + 2/3).
I have tried setting the images to a custom css. Having tried the following codes, but does not seem to work:
.photos {
background-size: contain;
background-repeat: no-repeat;
Current Website Url: http://leapdsc.com/leapdsc/client/hdb/delivering-homes/
Image Example: https://1drv.ms/i/s!Ai3uwVtbSehuuIUJtJKMT0B5Rdqwlw
Please do correct and advise me accordingly. Thank you.
Hello leapdsc,
Unfortunately, I do not know, what exactly you have added this image to your post page and why it is stretched, sorry! I have made a test on my side, using your image and add it in a simple post. The results which you should optain might look like this -> https://www.screencast.com/t/yE83GCBCbg Try to remove this image and add it again from your Media Library and check the results. Clear all the caches before this.
