Having problem on menu section
My last and second last category of menu is not showing proper contents.Instead they are showing about us and contact us page.
This happens in mobile only,not onna desktop version.
How can i solve this issue?
If you have a mega menu on desktop and you also have the mobile theme plugin then the mega menu will not be display in mobile menu, only the normal menus with sub-menus
Please provide me a link where I can inspect this problem, in this way I will be able to provide you a better answer.
http://Www.Koreanly.com is site.
Please look at last and second last section of menu.http://Www.koreanly.com
Indeed these item menus are linked to about-us page -> http://prntscr.com/pepdsz that is because you have set this link set on that item menu, you’ll need to go in Appearance > Menu, select the menu -> http://prntscr.com/pepeo0 expand the last two menu items and change the link from there -> http://prntscr.com/pepeuo
