Having problem with Category Description
Category Description appears as if it was on mobile even that I am on a desktop. After the last update.
I tried to recreate this situation on my install, but for me everything seems to be ok.
Can you please provide a link where we can investigate this situation?
I erased them from the web page. I put one on but it takes a while to happen. I will print screen when that happen again. Thanks.
Since you told me that there was not any problem I decided that the problem was mine alone so I erase the cache plugin and every thing is working well. Thanks.
