Having problem with google fonts
since I’ve moved my site to another hosting I’m experiencing some issues with fonts on site (centralna.ba). Fonts on site are not the one I choose in theme panel. I tried installing another demo to maybe fix this but it’s all the same no matter what demo I’m using. You can see it here: https://ibb.co/gTxWAp.
I looked at console for errors or some warnings while loading site and I did found this: GET https://fonts.googleapis.com/css 400 (). Could that be the cause of this problem?
I’m guessing if this happened to anyone before so maybe you’re familiar with this issue. Could you please help me so the fonts are applying correctly on my site?
Mladen
Try resaving your font choices. Clear caching.
I did that, didn’t help, but after removing and adding theme again it’s fixed 🙂
