Having Problem
This ad is showing before sharing and tag widget, why not it’s showing after Tag and Sharing button?
You can open any post in http://www.gadgetsay.com and can see that ad is showing before sharing button and tags button, not only that ad, I already previously added my Adsense ad, and it was also showing me on that area.
Thanks..
Do you refer to this ad? – http://screencast.com/t/UlRZUXxjm I see that you use an ad plugin and it places your ad in the post content. If you plugin allows shortcodes you could try to render it bellow the share buttons in the code – http://screencast.com/t/342mEUjJfec
ThankYou Sir For The Reply, It Worked, I just placed that JS code under the ‘get_author_box
Regards
Gadgetsay
