There are two instances:
1) I am modifying the category-template and want to have the Author name be white. But it stays black. Perhaps I need to modify it somewhere else? See screen shot.
https://drive.google.com/file/d/194xeWJoNOhEoXjnEG4rDg6gB218sRQgi/view?usp=drivesdk
2) I am modifying the element on the home page (flex block 1) to make the Title white and the Author white. But it stays black. So same basic question, where do I correctly modify this? See screen shot.
https://drive.google.com/file/d/15a33wIYZfYYukF8MFMO-zifEPReVq7Je/view?usp=drivesdk
The access is denied for those screenshots.
Please make sure you edited the author for the right module of the flex blocks element. In the settings it’s possible to have 2 options(author text color) like this: https://www.screencast.com/t/9zAi2oNms4S
Let me try this again with screenshots you can see.
https://www.screencast.com/t/S99W838P
In order to edit a category with TagDiv Composer, you need to access your category in front-end and press the button Edit with TagDiv Composer. Please check our documentation: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Then, scroll and check if in that list are 2 options(author text color), and modify for the current module.
Check the settings because you can edit only from there(screenshot 2).
If you can not manage to change that color, then please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Our team will take a look!
Thank you, I would recommend that the two boxes (one for title and one for rollover title) have borders around them, so you can actually see that there are two boxes. Indeed I was making a stupid mistake, I am sorry to have bothered you.
