Header AD and Footer AD not showing
Hello
I am trying to add a Header Ad for my website but is not showing and I don’t know why.
I have this code that I added on the newspaper theme panel at ADS
https://imgur.com/a/tyl9oNh (Header AD problem img)
And for the Footer AD on my theme panel at ADS is showing but at Adspot form i have these options to select
https://imgur.com/a/9bciRvo (Footer AD Problem img)
Thank you and have a nice day !
Also here is my website
https://techstart.ro/
For cloud templates, you should use the element called “Ad box” from TagDiv Composer and there you need to add the ads: https://www.screencast.com/t/DmSFbTW94Sx. Edit the homepage with the TagDiv Composer, and add the “Ad box” element in your header and footer(scroll till footer when you edit the homepage) with drag & drop.
