Header ad problem
My adsense account was verified 1-2 weeks ago. Although I copied the code to the header ad part on Newspaper Theme, only the ads in the posts are seen, but there is nothing seen on the header. I also use “Advanced Ads” plugin, trying there too, but it doesn’t help. No header ad. What might be the problem? Thanks
No Need to use any other ads plugin …
after login dashboard go to Newspaper>>theme panal>>ads>>Header ad>> ” paste your ad code in header ads
As I wrote: “Although I copied the code to the header ad part on Newspaper Theme, (…) there is nothing seen on the header”
Hi stucat,
Please notice that our theme only takes your Google Adsense code and display it on the frontend and not edit it, sorry! Remove all of the untested plugins which might interact with your Ads and cause this problem, sorry! After you have made this, if the problem is still there, please provide your website URL so I can take a closer look at it.
