Header Ad problems
Hi! I get a huge gap between header ad and content when showing in mobile. Anyone can help solve this? See http://www.screencast.com/t/UOWBrHdFMp
It seems that this could be ad related – https://www.screencast.com/t/fWKfCLn5mos as you can see there are a lot of warnings regarding this. You can also try disabling all your plugins except Visual composer, clear the cache, purge cdn files and check again. Maybe a plugin is interfering in some way, I can not even see the ad at the moment – https://www.screencast.com/t/88I2amcd4v7F – https://www.screencast.com/t/hUsfaqdHuusA
