is there anyway i can add ads on header without using Theme panel?
even if it’s in the code i can do it i just need to find out where
hi,
If you want to place a custom code in the header then you should look for the header file that corresponds to the header style that you use. The header files are found here: http://screencast.com/t/lppryMeUA
Yes i just want to add without using the Theme panel,
Theme panel eliminate some codes that is not part of adsense
is that screenshot the exact place?
actually it kinda did but the whole ads is not showing on smaller screens
Well since it’s a custom code you added I cannot know what code you used and how you modified the header file. You should make sure the ad is delivered for all devices. Is this an ad you created or provided by an ad provider? Please provide an example as I cannot know what customization you made.
