Site is https://rvtravellife.com and I’m having an issue with a padding gap appearing below the header and above the footer on some pages. This occurs on the live sites, but when I load the page into tag div composer it renders correctly.
This is the home page live with the gap
This is the home page header viewed in tag div composer
The same gap appears on the home page footer live, but not the composer view
There is a similar, but not equivalent issue on the post and page viewss
If you can give me any insight on what’s causing this and how to correct, it would be appreciated. My other instance of Newspaper at https://thisoldcampsite.com is working perfectly with what is supposed to be the same formatting
