Header builder: same column for header logo and mobile menu icon
Is there a way to put the header logo and the mobile menu icon in the same column so that the logo is always alligned to the right of the mobile menu icon? When trying to put the logo in the same column tagDiv Composer always alligns the logo under the menu icon rather than beside it.
There is a setting for the logo for horizontal alignment, so you could align it like this for example – http://prntscr.com/n6egpu
You can import a cloud header template and see how they are made and experiment
– https://cloud.tagdiv.com/#/load/Headers
Check each of the column settings, for example – http://prntscr.com/n6eivn
Let me know if you have more questions.
