Dear Support-Team
For some unknown reasons the header color for the “Related Articles” block are not as required (look at the bottom of the following examplary article http://radiouahid.fm/tafsir-juz-amma-unterrichtsserie/ ). All other header colors are as they should be (#007200). Why is this the case?
Best regards
You can try this code, just enter it in Theme panel->Custom Css with this result – https://www.screencast.com/t/ZaAojA4h5
.td-related-title.td-block-title
.td-cur-simple-item {
background-color: #007200;
.td-related-title.td-block-title {
border-color:#007200;
