Header & Footer Mobile Issue
I would like to know that how is it possible to edit the following heading and banner in mobile view. I tried in the cloud template option, but there it has no option for editing the mobile header and footer. Please refer the pics for your reference. My website is http://www.editnews.in
And how can I make the mobile menu floating. Please help on the same
Image 01: https://postimg.cc/vcfZygKN
Image 02: https://postimg.cc/BX9JmZvH
I’ve checked the website, and it appears that the responsive header and footer are now loading correctly. However, based on your screenshots, it looks like the tagDiv Mobile Theme plugin may still be installed and active.
Please verify this on your side. If the plugin is installed, kindly disable it, then clear all cache. This should resolve the issue.
https://prnt.sc/QhAUwtLVmikb
https://prnt.sc/zu33gXOKP196
I have checked in another browser also but its the same and also its not showing the responsive theme. Already the mobile theme app is deactived from my end and also cleaned the cache. Could you help. Also as per your screen there is floating menu with the demo logo, how can I change it ?
I see. Another possible situation is that you may have more than one folder template, where one is set as Global and another is assigned individually to a page or Cloud Template.
Please go to Dashboard > Cloud Templates: https://prnt.sc/gbjPnubKRGHl
If you have more than one template, please keep only the one set as Global active. The Global template will then be applied across the entire website.
As you can see in the pic. I only have one option as my header and footer. I have issue with both header and footer. Its not getting fixed after many follow-ups.
https://prnt.sc/hWpM9jgfU-6o
https://prnt.sc/C6uyCYwPpGbl
I have designed the template as needed for me. For me I need “LC – Single Template” as my mobile view and “Single Post Template – Free News” as my computer view. How can I set it. I checked for the option by copying the “LC – Single Template” and making to mobile version but still when I give the mobile template option again the issue is raising for the header and footer as its not coming as intended.
https://prnt.sc/5lCrMMCukAqM
At the same time I only have one header and one footer. The only issue is that when clicking the mobile view, I am getting the below header and footer which is not present while editing the mobile view via tag div
Header and footer which I dont want and which comes when I click mobile version of the theme I want:
https://prnt.sc/bmwv-EnUe2yI
https://prnt.sc/thtJ3oi1fUbl
This is how front end shows me for the same mobile version tagdiv composor:
https://prnt.sc/XmKcb7mcrvEm
https://prnt.sc/x21NvOxFkM-f
I need exactly like this in mobile version without the black header and footer
Ok, now is understand the situation.
You have created mobile templates that you are using only for mobile, but you do not have a mobile header and footer, so those need to be converted, edit a mobile template and select the manager, you can convert the header and the footer – https://prnt.sc/j20mPExYC01Hhttps://i.imgur.com/TbDs2b2.png
Thanks it worked
I have another site and that site dont have option to convert. Could you please refer the screenshot and help me.
https://prnt.sc/HIfS04Cok3EX
The option to convert a header or footer will appear while editing a mobile page or a mobile template.
Pleased edit a mobile page -> https://prnt.sc/lOHNKHS22v8d
Or a mobile template -> https://prnt.sc/4vApjdiH2QRc
Then the option should be available.
