Dear support,
Please notice that I have 2 problems with the link from header only in the post themplate that are using the default design. The one that are using the clud library themplate are ok. How can I resolve that.
Also, there is 2 errors, I sent you the image.
https://www.roaliment.ro/wp-content/uploads/2021/01/eroare-roaliment.ro_.png
Thank you,
Claudia
Hello !
Please re-upload your image. As you can see here the issue that comes is because of this image which does not load: https://www.screencast.com/t/I0qM4L4j
Let us know the result !
