Dear Sir, i’m having a problem in header menu, when i open any page/post the header menu didn’t shown, when scroll up or down then it is showing the menu… please check the screenshot https://i.imgur.com/qWFLibJ.jpg
Hello arslanlibrary,
Ensure that you are using the latest version of the theme, remove all of the untested plugins, clear all the caches and check the results. If the problem is still there, please provide your website URL so I can take a closer look at it.
Sorry for late reply sir, i was sending reply from email and its getting failed.
Sir i have the latest version of theme, and i don’t have any untested plugin. i have check all the things but problem exists. my website URL is arslanlibrary.com.
Thank You
