Header not showing on posts
Good day – my header shows on my pages but is blank on my post. How do I display the header on posts? Many thanks
Usually the header appears across the whole website. Do you use a cloud library post template? did you edit the template header using the header manager? Please provide a link to your site so we can inspect it.
Thank you – my mistake – I did not add a Logo in the Theme panel (under Header) – all fixed now!
Deon
