Header picture constantly pixelated on Beauty Pro
Hello this is my second site with Newspaper & I’m so excited, though I have a huge problem. Any photo I add to the header (background) space on the beginning of the page turns out awful & pixelated as seen on http://www.itsallgreektome.gr How do I fix this guys? (tried regenerate thumbnails with no luck)
Hello??
The background image can be blurry when the image is smaller and need to be stretch or when you have set a smaller thumb for that image, make sure that you set the full size for the image that you have set as background, for example-> https://www.screencast.com/t/jpRewXcCd
Hope this helps you!
You saved my life thank you ☺️
I’m glad that the solution helped you achieve what you want.
Let me know if you need further assistance.
Have a nice day!
