Hi ,
I have imported the header from cloud and make my change screenshot ( http://prntscr.com/mzy08l )
But I have a problem with the sticky bar Menu screenshot ( http://prntscr.com/mzy43p )
How can I remove this as there is no option !
regards ,
If you want to change the sticky type -> https://www.screencast.com/t/dDpQyrh36 also if you want to remove it you can delete the row -> https://www.screencast.com/t/Km5pL3xj or you can hide that zone -> https://www.screencast.com/t/XAtkVq3q -> https://www.screencast.com/t/bTZdQE8Fgm
I think the better option will be to delete the that row from sticky menu.
Hi Calin ,
Thank you for your reply ,
I have a problem The Menu was like this ( http://prntscr.com/n8rgv2 ) but once I linked the Menu with the categories it become like this ( http://prntscr.com/n8ri7y ) (http://prntscr.com/n8rich ) How can I link this menu with the categories and to be like the first screen .
Regards,
The easiest way to achieve that will be to force the width for menu -> https://www.screencast.com/t/U6LE1gvlFf1
Hope you understand I don’t want to menu to be like this ( http://prntscr.com/n95r6k ) I want it like this ( http://prntscr.com/n8rgv2 ) , once we linked the Menu with categories it changed, and for the header we get from the Cloud
If I understand correctly you do not want to gave mega menu -> https://forum.tagdiv.com/mega-menu/ only the simple menu with sub-menu -> https://forum.tagdiv.com/main-menu/ if is this, than you need to go in Appearance> Menu select the menu and remove the mega menu -> https://www.screencast.com/t/dt8HJ4gU
Hi ,
I was able to fix this and linked categories with Menu but I have a question please
How can I remove the word Category from the link (http://prntscr.com/n9lt8n )
Check the webstite : https://machahir.ma and check the menu I want it to be linked without showing the keyword category,
and I’m sorry for asking a lot of qquestions as I searched and maybe don’t know how to search for this exactly
Please check those articles:
How to change your WordPress permalink structure -> https://yoast.com/change-wordpress-permalink-structure/
The perfect WordPress SEO permalink structure -> https://yoast.com/wordpress-seo-url-permalink/
Hi Calin ,
I want just to say day after day I become the biggest fan of this theme, I really found what I was looking for , last time you gave me a custom Css code for the background ,
Now I found the template through tagdiv cloud and I use Tag div compser to change the background color for each element but what I notice is when I refresh the page it become “white” before it turnes to Grey screenshot ( http://prntscr.com/ne97k3 ) could you please give me the updated css code for this change which will show the page grey immediately website :saharapolicy(.)com
and again Thank you so much Calin
That is happen because first is load the style from theme files, only after that is load the style from theme panel, what you can do is to set the css in theme files -> https://www.screencast.com/t/sKt8qi631m wp-content/themes/Newspaper/style.css or you can set the code in Theme panel>Analytics/JS Codes ->https://www.screencast.com/t/htFOQ1yUpegD in header
<style>
.td-main-page-wrap {
padding-top: 0;
margin-top: 48px;
.td-post-template-4 .td-post-title ,.td-pb-row, .td-container-wrap {
background-color: #f7f7f7;
</style>
-> https://www.screencast.com/t/ETkRifNIqOiA
Hope this will help you!
After Application of the code given by you it be become like this ( http://prntscr.com/nfbrln) so how can I make the white also grey
Reply via this topic -> https://forum.tagdiv.com/topic/change-background-color-5/
