Header problems w Mega-Menu and Style8 – Height, blanc boxes, etc.
Hi everyone on TagDiv,
first of all congrats to Update to 8.1. – really great again and the TagDiv-Composer is awesome (after you get used to it) 🙂 … – great new ideas and possibilities. Keep up the great work!
During the update I found a few problems, I do not know, where to change or where to search. Please check attached screenshot with numbers from 1 to 3
Header - pureGLAM.tv changes
1. We use MegaMenu on this layout, unfortunately the height of the menu is to small – approx. 20px – to make it look nice, I need a height of 40-45px – where to change it?
2. Below nearly every page is a white line which will ruin the layout. Not only on the Home-page, also on
e.g.
https://www.pureglam.tv/fashion-blog
https://www.pureglam.tv/technik-blog
https://www.pureglam.tv/beauty-blog
How to remove them on individual page-IDs?
3. Where to change the background color of the Top-menu. Unfortunately not possible to change on Theme colors.
Thank you for your assistance and keep up the great work and great support!
1. Please check the line height settings for the menu items and increase the value if necessary in the theme panel
– https://www.screencast.com/t/QyhnOr3BOxh
Also if you have custom code targeting the header, or made other modifications to the header check those as well.
2. That is a padding top set by the theme. You could remove it with a code like this, in general
– https://www.screencast.com/t/h345SZ6WZ5v
.td-main-page-wrap {
padding-top: 0;
Or maybe by page ID (this can be identified with the browser inspector for example)
– https://www.screencast.com/t/2ck6LgpNDag
Enter the code in Theme panel->Custom CSS section.
3. There is an option in the theme panel that allows you to change the top menu background color
– https://www.screencast.com/t/e2EXgiPbOqE
Change the color there and it will have to be displayed. Clear any caching installed after making the modification.
Dear Simion,
thank you – all questions answered and all problems fixed…
Appreciate your great assistance.
Vanessa
