Header style and footer style is not showing in both header and footer section in my theme
Please help me as soon as possible.
here are both screenshots
screenshot:1 Header section
screenshot:2 footer section
Please make sure you have the tagDiv Standard Pack plugin activated, also clear your cache, from the last update, this plugin is no longer required because the new demos are using cloud templates.
You can use a header template from Cloud Library, and you can customize it with tagDiv Composer => https://www.youtube.com/watch?v=HXQQygkCCJo
Let me know the results!
