I would like to activate the header style 1, but change the header ad position in the mobile view (below the main menu, not above).
Basically, I would like to have the style 1 header for desktop and tablet and the way header style 2 looks on mobile.
How can I change the header style 1 (e.g. by using some code) to make the header add show below the menu bar and not on top when viewed on a mobile device?
Please note that I do not use the mobile theme, just the responsive one.
If you are using the responsive version of Newspaper theme you can use the header manager to create different header for each device -> https://tagdiv.com/newspaper-theme-customize-the-header-manager/ -> https://www.screencast.com/t/6yxooJLByFZ
