1. I want my logo to align with the menu. At this moment there’s a white space on the left side of the logo. How do I get te logo to move a little bit to the left. http://luikenkarstens.nl/rietlanden/index.php/home/
2. I want my logo to be bigger, but no matter what i do the size stays 272×90 (also in header 9). How can I change the size of the logo?
I hope you can help me fix these problems..
Please try this custom css in Theme Panel > Custom Css – http://screencast.com/t/Vd1WoJ1WopS – http://screencast.com/t/z5sp2KzeaN
.td-header-style-1 .td-header-sp-logo {
margin-left: 0 !important;
@media (min-width: 768px) {
.td-header-style-1 .td-header-sp-logo img {
2. For the default header style you will need custom modifications to change the logo width, you could try this solution – https://forum.tagdiv.com/topic/logo-auto-re-sizing-problem-in-v6-3/#post-60395
Also using the header style with full logo, it should display the full size of your image. Please note that it will not resize it, you have to upload a bigger logo.
I have also checked this using header style 9(full logo) and did not found any issue, it display the full image, please check – http://screencast.com/t/qjqSOdPY – http://screencast.com/t/GG0vI8Xd There is no specific css like on style 1 for example which was designed to have the logo and the header ad side by side and it needs css code for this.
