Hullo!
Ive used the Blockchain header template and made a website and a mobile view, but I keep getting the Blockchain logo on mobile no matter what i do. I also can’t default to the mobile site Ive made, it just pulls my webpage, and this is showing the Blockchain logo.
I also cant set a mobile footer without making a completely new mobile view.
Ive been through all the theme settings, help!
au4championship.com
TIA,
Sammy
That probably means that the logo wasn’t changed in the mobile header. To explain a bit, a header can have up to 4 versions, meaning 4 different logos. There is the default desktop header and the sticky desktop header, and there is the default mobile header and the sticky mobile header. These versions are independent of each other.
There is a guide here -> https://forum.tagdiv.com/add-logo-newspaper/
So using the website manager, if you click on the mobile header -> https://prnt.sc/OYqu-Z-k-24g Then you can customize the logo -> https://prnt.sc/phPAGxHaT-zS
Or click on anything in the page and switch to mobile -> https://prnt.sc/Dj9ABv5q6evC then customize the mobile logo.
Then do the same for the mobile sticky header. Either switch to it from the website manager -> https://prnt.sc/m09kH1UroHel Or simply scroll a bit down while in mobile view.
In case there are any issues let me know.
Thank you for the erply, Ive done as you have stated but it seems that the header stil defaults on individual pages to the theme template Ive used – surely the global change shoud run across all pages as a default? Ive done soething wrong there.
Also, the pages are not happy, sitting underneath the header half the time and nothing is helping ot pad or space them out. Is this beause I havent used a theme page and am using pages I had already created in wordpress rather than the tagdiv builder or a template?
thank you!
Actually that demo uses two headers. They should both appear in the cloud library dashboard, for example -> https://prnt.sc/ai3_p1GizDYY I should have mentioned this before.
There’s an overlay header, used just for the homepage I believe, and a regular header used for the rest of the website.
An overlay header means it is displayed over part of the content, and it’s usually transparent.
You could use just one header if you want or if it’s better for your website. To make the homepage use the global header instead of the special overlay header, while editing the homepage with the composer please set the global template here -> https://prnt.sc/I2g_blW_UFSd
To explain how that works, you can have different headers if you want, per page. A page can either use the global header, or a specific header if it’s set here -> https://prnt.sc/mcE-54JaWjw_
Please let me know in case there are further issues.
