Hey,
Have a look at this image: https://imgur.com/a/WSh0y , the first paragraph has been written with “Paragraph” selection while next paragraph has been written with “heading-5 ” selection.
Though it appears as per settings after publishing but on the post writing/editing panel, both looks same in size and boldness. I remember that with default WordPress theme or with my previous theme , these heading-4 , 5 and paragraphs etc, used to appear different of different size and hence it was easy to understand the difference between subheadings and content while writing the smart lists or any other posts.
How can I achieve the same thing here? Why it doesn’t show different sizes for different selections?
Please help.
Thank you,
Different themes have a different style added for the heading tags. In our case the heading 5 simply adds a slightly bigger dont size. It increases from 15 to 17 pixels. If you want to change this implementation you can edit the size fort heading 5 from the fonts section of the theme: http://screencast.com/t/dcmct1q0
This will only affect the front-end though. The backend can only be edited from the editor-style.css file here:
http://screencast.com/t/yqu2QQL50J
You can add maybe a font-weight:bold; to it in order to make it bold or increase the font as this file will only affect the back-end. They are 2 separate stylessheets so 2 separate elements.
I always love getting a reply from you. It’s always so well instructed :). Thank you.
I have already changed the front-end fonts and size for h5,h4 tags and currently I was only concerned with the backend. I will try this option soon and will ask you if needed any further instruction. Thank you very much. 🙂
