Help
Please can you help me. I design my home page with tagdiv but when i put some text, i can’t edit (design the text) so i return with the classic editor but i see only crypto text, i don’t see my text so i can’t change it like normal text .. How can i solve this problem and just design my text like i want.
I see this, it’s impossible to change my text … and with tagdiv, it’s not possible to design my text so how can i do ? Screen: https://ibb.co/hKDzh0r
THanks
Hi Minikal,
If the page was made with tagDiv Composer then in backend will be display only shortcodes like this ->https://ibb.co/hKDzh0r if these appear on forntend to then you need to activate all the theme plugins ->https://i.imgur.com/rxGKoa9.png
Also if the page is edited with tagDiv Composer -> https://i.imgur.com/hfr2Zu8.png you can click on the elements and change theme from sidebar options -> https://i.imgur.com/IVzgoRt.jpg usually the text is set on page s using column text or text with title element -> https://i.imgur.com/dym6Ewg.png -> https://i.imgur.com/HZu5cp2.png
If there is still a problem, please provide some more details and screenshots about what you want to achieve.
Hello Calin,
Thanks for your answer. If i change the text like your screen (Edit element) can i use another editor like Gutenberg Advanced ? Because there are not a lot of options to edit the text (like create table and so on …) . If i create my page only with the Classic Editor and Gutenberg (front end) and if i make some modifications after with Tagdiv, all my page is delete … i don’t understand how can i use both (tag div + gutenberg to have more options with the text)
You need to use only the editor with what you start the page, if this was tagDiv Composer, then you need to use only tagDiv Composer, if it was Gutenberg, then use only Gutenberg, is not recommended to use more editors because you can get errors.
