Help
Bought this theme because was told it had good support!
Have not seen this to be so as yet. My mobile them isn’t showing menus, and have no clue as to how to fix it
If you are using the responsive version of Newsmag theme, the on mobile you’ll have the menu that is set for desktop version.
If you are using the mobile theme plugin, then you can set the mobile menu from here -> https://i.imgur.com/EyUkXZ7.png
If there is still a problem, please provide me a link where I can inspect your mobile version.
