Help
Please how do I setup newsmag from scratch without importing demo?
Without importing a demo you will have to create a homepage with the composer and set it. And also you will have to set the templates yourself in the theme panel, for posts, categories, etc. It is perfectly possible to create a website without importing a demo, it just takes more time.
A demo will provide a homepage, and also set templates. Besides this, it usually imports some design in a separate stylesheet.
It will be much easier to begin by importing a demo and then customizing it as you want. Start with any of them https://demo.tagdiv.com/select_demo/select_demo_newsmag/ and then make modifications to it. Choose the one that looks the closest to the result you are looking for.
Either way, we will help. Let us know if you have questions.
