When I scroll to the next page it shows me a 404 error. How I solve this?
Hello @RahulDasOp !
It seems to be a problem with your permalinks.
Do you use any plugins for redirections?
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Hello @rahuldasop !
We can take a look, see exactly the issue and let you know what you can do there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cpanel url and credentials
I am encountering an issue on my website. When users sign up, they are informed that a password will be sent via email. However, the email sent from WordPress contains a password creation link leading to my WordPress admin URL. Additionally, I am unable to locate any emails on my website.
*There is a problem in tagDiv support to create a new topic**
When visitors sign up, WordPress automatically sends them login credentials for access to my website. Consequently, this grants access to everyone on my WordPress admin panel who signs up. How do I sort out this problem?
This reply was modified 2 years by
rahuldas.
I am encountering difficulties on my website as I am unable to locate the Register option; only the login button is visible. both mobile and desktop.
Hello @rahuldasop !
When you click on my account, it looks similar to this: https://app.screencast.com/eom2IZ5tGkH05
Check in an incognito window.
Hello @rahuldasop !
Make sure you have the latest update to the theme and plugins.
Make a test and deactivate all plugins except tagDiv ones. Also, if you are using a cache plugin, deactivate it, clear all cache, and try again.
If the problem is still there, then please provide the credentials of your website via email in order to check the issue and try to help you.
There seems to be an issue with the theme of your newspaper, and I couldn’t locate a registration option on your demo website.
You must have the option enabled “Anyone can register” box => https://www.screencast.com/t/CS3WbdwMR please go to Settings > General to have the register option.
