Hey there! I´m thankful for have bought this theme, it´s awesome! I´m founder a photo magazine blog project called http://fotomundi.org
Now, I sell advertising at my blog, but i need the body width be only 580px. How can i make it? Is there any custom code?
This is I want http://fotomundi.org/wp-content/uploads/2015/12/HELP.png
Yes you can. if you have custom Adsense code for it, which i doubt.
but you can display an Ad in that spot. Just go to theme panel > Ads. Create it.
then with Visual Composer on your front page, you can drag and drop it to your desired spot.
As i understand it you want the whole page width to be 580px. This will be a bit hard to accomplish as all the elements in our theme depend on a fixed width. If this is changed, then all the elements will not align properly anymore. So depending on what elements you have on a page that has an altered width, you will need to adjust those elements as well using css. It will be no easy task. The theme has no setting to adjust page width so you will need custom modifications in the theme files so if you cannot do it yourself, you will have to hire a freelancer to help you on this task as we cannot offer any custom work at the moment.
