Help about custom bangla font, footer background etc
Hi there,
How can I change the custom Bangla font? I want to change every Banga font style with SutonnyMJ font. Only Bangla font, not other fonts.
How do I change the footer image? desktop and mobile version.
Footer background image
If you want to use a custom font like SutonnyMJ, then you need to upload it with .woff format in theme panel -> https://i.imgur.com/yRaKiHy.png after that change it in theme panel fonts -> https://i.imgur.com/JvCtb5k.png also note that if you are using a pro prebuilt website the fonts need to be edited with tagDiv Composer then select the elements and check the style tab -> https://i.imgur.com/jL31rEc.jpg
Also to change the background image from footer scroll to that section, select the row from footer and in css tab you’ll find the background css ->https://i.imgur.com/Yq06HV5.png
I hope this will help you!
