Help about How to use skyscraper as banners out of "working zone"
Im trying to insert "skyscrapers" as banner with the Plugin WP PRO ADVERTISING SYSTEM; but I cant found “space out” of the Theme Pannel!
Can you help me? I think in the Background, maybe I can do something in the configuration; and I have try too with the widgets, … but I finally don’t find the way.
What I want to do is something like the banner of pub you can find in this newspaper: Newspaper image with 2 skyscraper as pub banner
Thank’s in advance.
BR
I’m not sure what you mean and I haven’t managed to realize it on the mentioned site either. Do you need ad banners here: http://screencast.com/t/nAnONkwwCGL If this is the case please note that the theme doesn’t have any options for that so you would have to customize its ads system for that or use another plugin or a ads codes. If you don’t know how to do it we advise you to ask the help of a developer or a freelancer because you need custom work for this.
If you refer to this one: http://screencast.com/t/HqgW66nU then you can use theme’s ad sport for that and place your ads, using VC page-builder or theme’s/wp widgets, wherever you need them. Please see theme’s ads guide and let me know if you still need assistance on this afrewards: https://forum.tagdiv.com/ads-system-full-guide/
Hi Lucian; the first one is the one I want to to. I have try too with the background, but it doesn’t work! I will try with the publicity plugin; but I think as you told me that’s not easy.
BR
Finding and using a plugin would be your best option as the theme doesn’t have any ad spot that can place an add like that.
We will consider adding this possibility in future updates if we decide to improve theme’s ad system.
